  2. Allegro X Capture CIS
  3. Need help with TCL code to modify offpage
  • State Verified Answer
  • Replies 7
  • Subscribers 49
  • Views 14382
gvellet
gvellet over 3 years ago
Sorry I have to ask another question about TCL scripts to fix problem with schematic imported from Mentor PADS.
This time the problem is with the imported offpage symbols. The "Name" property value is wrong; it is always "PIN0" instead of the associated net Alias, and also the property value is hidden (impossible to make it visible through orcad GUI interface). As ripple effect, the offpage Name values override the net Alias resulting that all nets with offpage symbols  are shorted to this dummy "PIN0" net.
I made a TCL script to edit all the offpage symbols, it modifies the Name property value to match the net Alias and to make the value visible. The script works but there is a big problem, the netname do not follow, they either stays stuck to "PIN0" or more strange they are reassigned to random valid netname. The script modifies the offpage instances and I wonder if it is a problem where occurrences should be modified instead of instances. I tried a little to change my script for occurrences but I run into problems that the object method I need not working or I do not know which method I should use.
I also wonder if the problem is more like I must trigger something in Orcad to tell it to copy offpage name into the wire netname?
Please I need some expert help. I have attached a zip including the tcl script and an anonymized schematic with the buggy offpage.
Best regards,
gvellet
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/109/offpage_5F00_test_5F00_archive.zip
  • CadAP
    CadAP over 3 years ago +1 verified
    HI Gvellet, Please find the attached file modifed tcl scipt and modified anonymized schematic with that tcl script . I have added line catch {DboTclHelper_sEvalPage $lPage} before proceeding to…
  • WQIA
    0 WQIA over 1 year ago in reply to CadAP
    Yes. I have never used TCL scripts. The only thing I know is that is from Capture Command window. But I don't know the format of the TCL command line with old and new offpage names.
    We are having an OrCAD drawing that have tens to a hundred offpage names of "DIO_n_AIO_m". Both n and m are incremental. One easy (less prone to error) is to rename/substitute in batch.  I tried to do it with Excel table trick. But it didn't work. So I searched and found this page. It seems the TCL script can do what I needed. But I don't know how to use it.
    Thank you very much for help.
  • CadAP
    0 CadAP over 1 year ago in reply to WQIA
    WQIA
    Please check below article:
    Article (11798906) Title: What are the different ways to source a Tcl file in Capture?
    URL: support.cadence.com/.../ArticleAttachmentPortal
