  2. Allegro X Capture CIS
  3. PACK_SHORT Property on Heterogeneous Symbol Causes Erro...
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 6858
PACK_SHORT Property on Heterogeneous Symbol Causes Error
grmnrsbonini
grmnrsbonini over 2 years ago
Working in Capture CIS 17.4, I've created a heterogeneous multi-part symbol to separate the power and signal blocks of a component.  I've added the PACK_SHORT property to the symbol to tie the thermal pad (EPAD) to the negative power pin (V-).  The EPAD and V- pins are on part 'B' of the symbol.  Let's assume the part refdes is U1.
Once the symbol is placed on the schematic, I get an error stating the V- pin in the PACK_SHORT property doesn't exist on U1A.  There is also an error stating that there is a pin count mismatch between the U1B symbol and the footprint, however U1A+U1B has 9 pins, and so does the footprint.
I assume both of these errors stem from the same underlying issue.
Is there a way to resolve these errors or can PACK_SHORT *only* be used with monolithic symbols?
Thanks!
  • AyushD
    AyushD over 2 years ago in reply to grmnrsbonini +1 suggested
    Just try to delete the value of the property from that section not the property itself
  • tzsolt
    0 tzsolt 11 days ago in reply to AyushD
    In the olb library if I delete from the other sections only the value of the PACK_SHORT property then the value disappear from the original section too!
