  2. Allegro X Capture CIS
  3. Differential Signal symbol
  • State Verified Answer
  • Subscribers 50
  • Views 3648
KD202502275710
KD202502275710 over 1 year ago
How to put differential signal symbol in Orcad capture 17.4
  • Jeet
    Jeet over 1 year ago +2 verified
    Are you looking to assign signal properties on net? The property is DIFFERENTIAL_PAIR, This property represents a pair of flat nets that will be routed in a way that the signals passing through them…
  • Jeet
    Jeet over 1 year ago in reply to KD202502275710 +1 verified
    To view a differential pair go to Create Differential Pair dialog box, select the Differential Pair option from the drop-down list. All the differential pairs you created in your design appear in Diff…
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to Jeet
    Thanks Jeet. You've been helpful.
