  2. Allegro X Capture CIS
  3. Assign Power Pin to Power Net of Different Name
  • State Verified Answer
  • Replies 7
  • Subscribers 51
  • Views 8758
anowack
anowack over 1 year ago
Hi there,
I've read several topics on this, and remain confused on how to address this topic.
I have several parts with different naming conventions for the power rails, some support single supply, some dual supply. Another has two different voltage supply sources. Between these parts I have power pin names of GND, VEE, VS-, VCC, VS+, VDD, VCC_2. I have global nets named +5V, +3_3V, GND, and I want to connect them to these pins as I choose. I would prefer to not alter the schematic symbol pin names, as I intend to reuse these parts in the same schematic with other instances connect to other voltage supplies.
When running the DRC I get many errors of "Warning,Electrical,WARNING(ORCAP-1589): Net has two or more aliases that might lead to a short. Ensure nets are not shorted together or nets do not have two or more aliases. This message is displayed because 'Report all net names' is set in Design Rules Check dialog.,U4,VCC VCC  +5V,SCHEMATIC1"
What is the correct way of doing this? I tried adding a POWER_GROUP property to the part instance with entry of "VDD=+3_3V" but this did not result in any changes.
Here is an example picture from my schematic, and the DRC marker from before is from the VCC pin on this part
Thank you
- Aaron
  • gvellet
    gvellet over 1 year ago +1 verified
    If you think like me I guess that you are always connecting the symbol power pins in the schematic to a wire. (Instead of leaving the pins floating, and relying on global net assigned to the pin.) In…
  • DH202512105348
    0 DH202512105348 6 months ago in reply to oldmouldy
    If you do connect a power pin to a net, does that net get shorted to the net with the same name as the power pin?  For example. If I have a part with power-pin named 'GND', and I connect it to a net called 'AGND', will the 'AGND' and 'GND' nets be shorted, or does that only happen if a power pin is left un-connected?
  • oldmouldy
    0 oldmouldy 6 months ago in reply to DH202512105348
    No, "deliberate" wire connections win over unconnected Power Pins.
