  2. Allegro X Capture CIS
  3. Creating Parts
  • State Suggested Answer
  • Replies 11
  • Answers 1
  • Subscribers 53
  • Views 6011
Creating Parts
DI202504182336
DI202504182336 over 1 year ago
I am not able to navigate to Component Explorer to create a part using the methodology given in the tutorials.  In the tutorials, the "M" hotkey should open Component Explorer but that doesn't work. The tutorials also show browsing to Component Explorer the path, Place > Component Explorer, but at Place, I don't get a Component option (only Part, Wire, Bus, Junction  etc.
  • oldmouldy
    0 oldmouldy over 1 year ago in reply to DI202504182336
    There isn't anything missing or intervening. The Place>Component menu is not available with the 17.4 version, it wasn't introduced until the 22.1 version. In any case, as others have mentioned, creating Parts through the Place>Component menu uses the Search Providers to obtain Schematic Parts and Footprint data from online resources. If you want to create a Schematic Part "from scratch" in 17.4, use File>New>Library, to start a new Library and add parts, or use File>Open>Library, to open an existing Library and add parts to that.
