  2. Allegro X Capture CIS
  3. Bill of materials
  • State Verified Answer
  • Subscribers 44
  • Views 786
Bill of materials
XB202505151455
XB202505151455 7 months ago
When Capture generates a BOM, the Bill of Materials menu does not have the options \ tPCB and \ t {PCB Footprint} by default, and must be manually added each time. I don't know if there's a way to make it default?
  • Jeet
    +1 Jeet 7 months ago
    The settings for the header or combined property string "line item definition" are stored at the project level, not at the Capture.ini level. The information contained in each of the reports is stored in the Project file. Since there is no default Project file template, any new project is generated from Capture.exe which contains the hard coded defaults.
    As of now there is no way to permanently change this, you can set up your own TXT file with the information you wish to use and then paste it into any new project file.
  • XB202505151455
    0 XB202505151455 7 months ago in reply to Jeet
    Got it, thank you!
