  2. Allegro X Capture CIS
  3. OrCAD Capture annotation issues for a heterogenous part...
  • Replies 7
  • Subscribers 51
  • Views 2191
OrCAD Capture annotation issues for a heterogenous part in a hierarchical design
SF202503203610
SF202503203610 5 months ago
I have a hierarchical block that is used 64 times.  Within that block I have a quad opamp that was pulled from the included OrCAD library.  The reference designators are U?A, U?B, U?C, U?D.  When I annotate this block, (Update Selection is selected). I do not get the annotation that I desire.  I want
Instance 1:  U1A, U1B, U1C, U1D
Instance 2:  U2A, U2B, U2C, U2D
Instance 64:  U64A, U64B, U64C, U64D
but what I am getting is
Instance 1: U1A, U2B, U2A, U2C
Instance 2: U1B, U3A, U2D, U3B
etc
I have tried using Update Occurrence, Update Instances:, Annotate as per PM Ordering, Annotate as per page ordering in the title blocks, Preserver Designator, and Auto-package Heterogeneous Part Using First Match, and they seem to have no effect.  I have tried "Advanced Annotation"  but it just opens and locks up.  The only button that works is the X to close the window. I even changed the reference designator for this part to UQ?A, UQ?B, UQ?C, UQ?D so that there would be no conflicts with any other "U" parts, and the output was pretty much the same.  I have OrCAD X Capture 23.1, but I have noticed this behavior in previous versions of OrCAD.
I'm beginning to think the only solution to this is to annotate it, then go in and manually change all 256 reference designators (4x64).
  • SF202503203610
    0 SF202503203610 5 months ago in reply to Jeet
    If I click the image/video file it has for the file or a URL.  If I click "upload" and select a file on my computer, I get a small orange window in the upper right that says "An error occurred. Please try again or contact your administrator"
    It says it can be a file or a URL.  If I past a URL to postimages, it shows an image, but the post fails and I get notified that my post was flagged as SPAM and it asks me to write an appeal (which I did).  If I post an imgbb link in that window, the image doesn't even show.
  • Jeet
    0 Jeet 4 months ago in reply to SF202503203610
    Can you please try uploading a image of small size would request you to please share the ERROR code which you are getting while annotating the schematic design.
