  3. Automating Gerber Generation
  • Replies 8
  • Views 22908
wERerABbiT
wERerABbiT over 18 years ago
Hi All,
I would like to write a skill program to automate the gerber generation. May I know:-
1) Are there any functions (skill or axl) that allows you to manually generate a certain gerber layer rather than using the MANUFACTURING -> ARTWORK dialog window?
2) Are there any functions that allows you to import a predefined setup for the Artwork Layers? If not, any suggestion on how to do this in a skill program?
Thanks All
  • DE202408202727
    DE202408202727 over 18 years ago +1
    Here is a function that I would use (if I didn't output ODB++ exclusively these days): defun( MY_GerberOutputs (filmNames) let((cmd) axlSaveDesign() sprintf(cmd, "artwork%s %s.brd", buildString(mapcar…
  • wERerABbiT
    Thanks Vramanan!! :)
    Unfortunately I can't download the file. Please repost file.
  • vramanan
    vramanan over 18 years ago
    oops sorry
    Here is the zipped skill file
    fabout_back.zip
  • vramanan
    These are the pre-requisites
    1.       The board name should be XXX-YYYY-ZZ_RVVV
    a.       The first XXX has 2 requirements one number for assembly rev and another for Fab
        i.      Ex 200 for PCB and 30X for assembly in this case
    b.      Also if it is 299 then it is internal and 200 if product
    2.       Pkzipc should be installed
    a.       You can install 7zip and modify the code
    3.       First generate all the gerbers/IPC/ODB/placement/NC-TAPE/NC-DRILL/Testprep before using scripts then run the fabout script
    a.       Look at example at the end
    4.       I use lot of batch commands to manipulate  zip file names and moving copying stuff
    a.       Change it to your requirement
    b. when you run the fabout it will create a t.bat examine its code to understand what it does, it is extensively commented
    setwindow pcb
    odb_out
    ipc356 out
    setwindow form.ipc356
    FORM ipc356 run
    FORM ipc356 close
    setwindow pcb
    plctxt out
    setwindow form.plctxt
    FORM plctxt body_center YES
    FORM plctxt filename ven_cntr.plc
    FORM plctxt execute
    FORM plctxt pin_1 YES
    FORM plctxt filename ven_pin1.plc
    FORM plctxt execute
    FORM plctxt cancel
    setwindow pcb
    setwindow pcb
    trapsize 44073
    reports "Component Pin Report" nographic write cpn.rpt
    ncdrill param
    setwindow form.nc_parameters
    FORM nc_parameters decimal_places 5
    FORM nc_parameters suppress_lead_zeroes YES
    FORM nc_parameters suppress_equal YES
    FORM nc_parameters done
    setwindow pcb
    nctape_full
    setwindow form.nc_drill
    FORM nc_drill tape_name nctape.drl
    FORM nc_drill scale 1.000
    FORM nc_drill separate_tapes YES
    FORM nc_drill auto_tool_select YES
    FORM nc_drill repeat_codes NO
    FORM nc_drill repeat_codes YES
    FORM nc_drill execute
    FORM nc_drill close
    setwindow pcb
    system artwork $module
    skill load "fabout.il"
    fabout
