  3. Extracting all elements from listbox
  • Replies 7
  • Subscribers 166
  • Views 18261
terrylau
terrylau over 18 years ago
I got a list box that I want to extract out all the fields in it - its a list box with OPTIONS sort. Using axlFormListGetItem() with a 0 and -1 will only get me the first and last element of the list field. How do I go about to be able to extract out all the fields? Appreciate any help as still kinda new to SKILL.
  • Ejlersen
    Ejlersen over 18 years ago
    You could try testing what type tempStr is with the command "type(tempStr)" - this would determine once and for all the type of the object and hence also what you need to use for your fprintf statement.
    %s should work for any string, so your tempStr must be something else - maybe a list? - in this case you may need to use
    • if( tempstr fprintf(TestForm "%s\n" nth(0 tempStr)))
    Here nth(0 tempStr) pulls the first element of the list
    Hope this helps,
    Best regards,
    Ole
  • terrylau
    Dear guys, thanks for your help... the problem's solved with the  if( tempstr fprintf(TestForm "%s\n" tempStr)).
    Looks like tempStr is a string after all. Thanks again and appreciate it very much.
