  3. Opening a PDF file with Skill
  • Replies 9
  • Subscribers 166
  • Views 21401
Geoff
Geoff over 17 years ago
Is there a way to open a PDF file from skill? (I am using windows XP)
In my Skill Program, I want to link layout notes (PDF) for certain components. That way I'll be able to know which parts need special attention.
  • satya12
    satya12 over 17 years ago
    Yes you are correct,it can read only note pad.
    I acn suggest one more option,you can import " .bmp file " using some skill file.,then you do not require to capture the stack up etc...
    Satya
  • soori3
    soori3 over 14 years ago
     I am unable to open the PDF file can you please help me
    before running the command where i need to place the respected pdf file...?
    Suresh Annam
  • DE202408202727
    DE202408202727 over 14 years ago
    axlPdfView
  • evanpan
    evanpan over 10 years ago
    Hi, Geoff.
    Thanks for your nice sharing. But when it comes to pdf processing problem, I have a question to ask you. I wonder whether I need some 3rd party pdf text extraction toolkits to help me extract text from pdf files. If so, it will be better if itt offers free trial package for users to check. I will try it later and send you feedback.
    Best regrads,
    Pan
