  3. Find component and find net SKILL programs
  • Replies 8
  • Views 19971
EvanShultz
EvanShultz over 17 years ago
Hi all,
I was unsatisfied with the Find_Component.il program on SourceLink. It didn't quite have the features that I wanted. Plus, the zooming was broken (in 16.2 anyway). So, I modified the file. It's not revolutionary, but it's a nice enhancement. I added the ability to open the Show Element window after clicking on a part and zooming to the part is now done by a button, instead of automatically.
Then I thought, why not do the same for nets? So, I modified the component program to work with nets, with the same additional features.
I believe both programs are working fine without any issues, but please let me know if you find any problems so I can correct them. I appreciate any feedback  you may have. This was my first foray into SKILL so I hope it's helpful for everyone.
I apparently can only have one attached per post so Find_Net.il wil go on the next post. I made them TXT files for posting reasons, change them to IL files for use (obvious, I know).
Now, wouldn't it be great to have this same functionality in DEHDL instead of the silly Global Find window? Of course you'd need instance numbers since the ref des isn't there by default, but I think it could be done.
  • Find_Component.txt
  • EvanShultz
    Craig has made a few fixes to his 'natural order' sorting function here http://www.cadence.com/community/forums/T/11133.aspx and I've used it in updated versions of Find_Component.il and Find_Net.il. Thank you Craig!
    There are also several usability enhancements in these versions of the programs and I highly suggest you update to the newest versions attached here right away. The zip file has Find_Component.il, Find_Net.il, and calStrNatCmp.il. Put them all into your PCB skill directory, load them all in allegro.ilinit, and you should be good to go.
     If you have any feedback please let me know.
    find comps and nets.zip
  • redwire
    redwire over 17 years ago
    Ok, I am changing your grade to an A+!. Nice work.
  • EvanShultz
     redwire, thank you very much.
    So, my remaining questions:
    1. Can anyone comment on the width of the forms? I expanded the Current Name box so you can see a little bit of the UNNAMED* nets. is that sufficient? Would you find value in having the forms wider?
    2. Right now Find_Component.il only lists placed components - would it be preferrable to list all components, placed or unplaced?
