  3. Help Needed for Quickplace using Skill/Script
  • Replies 8
  • Views 8326
vramanan
vramanan over 17 years ago
Hi Guys
 This is my intention
A script that will
1.Go and place all the symbols w.r.to its Schematic page number
2. Draw a dynamic rectangle around the placed symbols
3. Place a Text indicating the Page #
 I understand that I can do a script/skill  combination to do this
I can go around finding the exact numbers of pages by just giving a number and looping through it
 I see that the quickplace will create a log  which has xy for the placed symbols, I could use it to determine the Rectangle size
Any ideas/suggestions are welcome, I am willing to code and share it in the forum
If my above idea sounds viable, I need some pointers on reading a text file using skill
regards
Venkata
  • vramanan
     Hi if anone can help me on the following issue, it will be great
    This is what I want to do
    1. Open a text file (I know it)
    2. line read til you match a pattern- Having trouble
    3. once matched a pattern assign that line to a variable - (I know it)
    p = infile("quickplace.log")
     text = gets(s p)
    while( !rexMatchp("^Placed 0 of 0" text)    text = gets(text p))
    This seems not to work
     please help me
    regards
    Venkata
  • aCraig
    aCraig over 17 years ago
    This works for me.
    rexCompile("^Placed 0 of 0")
    while(gets(text p)
      when(rexCompile(text)
         ;do something
  • vramanan
    vramanan over 16 years ago
     Hi Guys
    I am not showing off but I have completed a Skill script that would help in quickly placing huge amount of components within a minute
    and also will help in tracking their parents w.r.to it's page / parent hierarchy etc...
    I have attached the presentation I did to my company, due to the amount of work involved , the time I spent as well some confidentiallity issues I can't post the entire code.
    But this post might give some Ideas how it is done and what else is possible
    Here is what I do in the skill file
    1. Get all the component definition
    2. Identify the logical path property
    3. Parse it such that you create groups of different hierarchy and Pages
    4. Once you have the list of all the hierarchies create lists for individual pages and their underlying components
    5. Now place them with respect to their pages/hierarchies
    6. calculate the new locations
    7. For tracking their parent's assign properties on the symbol level and use the treeview interface to highlight them
    I can give little bit more clues on the placement logic. search in google of 2D bin packing
    although I used a variation of this logic
    Basically I pre-sorted all the components w.r.to their size (you can either use place bound or pin count clue :-)!!!) on the individual pages
    then I sort all the pages within a given hierarchy w.r.to their size and sort all the hierarchies w.r.to their size
    Now I start on a given point and place the first component, since I pre-sorted it I am positive that the next member in that page is either same size or smaller than the first one.
    Now I place the second one and compare its extends with my pre-defined Page box if it fits I place it or i place it on the next row.
    This continues so-on and so forth for pages and hierarchies
     I have attached the presentaion which will give you some ideas how it looks
     I can answer your questions and give more info on the techniques but unfortunately I won't be able to post the entire code
    I appreciate the understanding of this matter
    Good Luck
    regards
    Venkata
    Infinera_PCB_QuickPlace_Tool.pdf
