  3. How to Add a Flight line in cadence (Skill function)
  • Subscribers 160
  • Views 14462
AmitBiswas
AmitBiswas over 16 years ago
hi, I wanted to add a flight line between two points or between two pins using skill command, anybody knows the command to get it. thanks & regards Amit
  • Randy R
    Randy R over 16 years ago
    axlDBCreateLine should work for this
  • erikwanta
    erikwanta over 13 years ago
    enterPoint(?prompts list("select net") ?addPointProc "afpCB")
    procedure(afpCB(w pts)
    prog((obj)
    ;select the point
    geAddSelectPoint(w nil car(pts))
    ;get the selected object
    obj=car(geGetSelSet(w))
    ;when the selected object is a net, add a flight probe
    when(obj~>objType == "line"
    ;add a flight probe
    geMakeProbeWithColor(?object obj ?window hiGetCurrentWindow() ?color
    _geGetProbeLPP(t) ?probeType "net" ?displayStyle "flight")
    ) ; when
    return(t)
    ) ; prog
    ) ; procedure
