  3. how to set all spacing values in scset to the same value...
  • Subscribers 159
  • Views 13477
how to set all spacing values in scset to the same value?
Ejlersen
Ejlersen over 16 years ago
Hi
I know how to use axlCNSSetSpacing to set a single or list of spacing parameters, but suppose that I would like to set all spacing values to 0.1mm without having to specify all the different object types available (hundreds I think).
Anyone have an idea about how I can do that?
Best regards
Ole
  • fxffxf
    fxffxf over 16 years ago
    A small helper routine can be written as follows:
    1) get a list of constraints:  lst = axlCNSGetSpacing(nil nil nil)
    2) use a foreach loop to iterate on this list
    3) inside the loop call axlCNSSetSpacing with nil for layer: axlCNSSetSpacing(<cset> nil  item <value>)
     If you like lisp the following might do it
            foreach(mapc x axlCNSGetSpacing(nil nil nil) axlCNSSetSpacing("DEFAULT" nil x 9.0))
  • Ejlersen
    Hi
    This works very well, thanks for your help on this. The beauty of doing it like this is that it makes it easy to check for changes if you're assigning to a cset that already has existing values.
    Best regards
    Ole
