  3. Get device type and value of component
  • Subscribers 160
  • Views 17088
ELEKVN
ELEKVN over 16 years ago
Hi all,
I want to read device type and value oc components, But
I meet one problem with this code below:
mydesign1=axlDBGetDesign()
                        compfind = mydesign1->components
                                    foreach(ref compfind
                                            println(ref->name)    ;I can
                                          println(ref->symbol->name) ; I can
                                            println(ref->devtype) ; I canot
                                          println(ref->value) ; I canot
                                        );end_foreach
( I can read reference and symtype of components, but I can not read device type and value of them )
Can you give me exactly command to solve this problem.
Thank you verry much
Elek
  • oldmouldy
    oldmouldy over 16 years ago
    Looking at the Allegro SKILL reference, "deviceType" is the attribute that you need, rather than "devtype", "value" is not a component attribute. algroskill.pdf, page 87 / 88 for SPB 16.2
  • ELEKVN
     Tks
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    All you need to do is the get into the compdefinition and get the value property
    ref->compdef->prop->VALUE
     Try typing ref->compdef->prop->?? to see a list of properties for that component definition.
    Best regards
    Ole
  • ELEKVN
     Hi Ole,
    Thank you for your imformation.
    I can get Value from your advice, but I can't get Device type
    Example:
    Reference Designator: Q2
      Package Symbol:       SOT23
      Component Class:      IC
      Device Type:          FDV337N_SOT23_FDV337N             (I can't get)
        Value:              FDV337N                                                 (I can get)
    I uesed comand :ref->compdef->prop->DEVTYPE  for get device type,
    Please help me correct it.
    Thank you
    Elek
  • Ejlersen
    Hi Elek
    Thats because you need to use ref->compdef->deviceType
    try using ref->compdef->?? to se more about this
    Best regards
    Ole
