  3. Opening a text file in Allegro
  • Replies 10
  • Subscribers 166
  • Views 21827
eddieb1
eddieb1 over 17 years ago
Is there a way to open a text file in Allegro? Or if possible is there a way to place the text file in the "Show Element" window to make it active (hyperlink)?
 Here's my situation, I have a skill code written by somebody to look for a specific bend (angle) on a trace. Once found the x-y location of the trace and layer along with the netname is reported/written on a log file. Problem is, it's taking too much time to go and physically locate the bend. So if the skill reported 300 bends, then the only way to locate the bend is to copy the x-y coordinate from the report then use a 'line ' command with the x-y to go to the specific location.  If I can somehow place the report unto an active reporting window like the "show element" window then I think my problem will be resolved.
Thanks in advance
Eddie
  • fxffxf
    fxffxf over 17 years ago
     To open an existing file via skill do: axlUIViewFileCreate( "<filename>" "<filename>" nil)
         the second arg is the title for window while the 1st is the file to open.
  • Randy R
    Randy R over 17 years ago
    The example should work fine if your report is written to the working directory; otherwise you will probably need the full path.  Another difference might be the delete file option.  Depending on whether you want to keep the report file, you may want to set it to nil instead of t.
  • eddieb1
    Thanks Fx,
     Works! Simple and elegant.
    Much ablige to you gentlemen (Randy/Fx).
    Ed.
  • ArsalanAzhar
    ArsalanAzhar over 12 years ago
     Hi
    i know this is long time ago. But kindly let me know if you able to make the xy coordinates in hyperlink, so it will easy to jump to the exact location.
    Currently i m using the old technique to jump by line tool.
    Your reply will be appricaited.
    regards
    Arsalan Azhar
    arsalan20@gmail.com
    arsalan.azhar@altanova.com.pk
  • Ejlersen
    Ejlersen over 12 years ago
    Hi
    If you write data to a file in the format (x,y) and open it in the html viewer it will automatically be a hyperlink
    Example
    fprintf(filehandle "Component located at (%f,%f)\n" xcoordinate ycoordinate)
    where both xcoordinate and ycoordinate are floating point numbers.
    Best regards
    Ole
