  3. Find and Replace Text Utility
  • Replies 9
  • Subscribers 167
  • Views 24130
vramanan
vramanan over 16 years ago
Hi
Warning: This is a partial code but does the work
after loading type "te" on the allegro command  window, when you choose a class/subclass, the grid will show all the available text in those layers(go up and down on the subclass to refresh the text)
The color button next to subclass will turn on/off that particular layer(thanks to dave elder's code)
When you click on a text in the gird, it will show up in actual text, you can change it there and press tab and it will be updated on the grid as well as the actual text
 For now I kept minium characters to be searched as 3, type it in the find box and press find button, this will only list those has the find pattern
 (find in all layers is not yet implemented, plan to show the layers in the second column)
type the new pattern on the Replace text and press Replace All, this will replace
(this funtion is incomplete because I am stuck at not able to refresh the grid, I know what's happening but I am little lazy to code it now
the dbids gets removed after replace function, I got to refind them and update)
Many Many thanks to Dave Elder since I am just improvising lot of his functions
I appreciate any feedback and comments, I welcome anyone willing to code further, I only wish me being indicated of the changes and willingness to share some code
regards
Venkata
  • vramananx
    vramananx over 13 years ago
    Hi Tommy I haven't been using that code for a while May be i should include a check for if the found text editable in 16.6 the dimension texts are not editable When I am free i will look into it regards
  • TommyBrunet
    TommyBrunet over 13 years ago
     Actually, the code is working now;  I think I had a database environment issue as I edited a file originated in Allegro with my OrCAD tool.  Thanks for the response!
  • abrusil33
    abrusil33 over 12 years ago
    Hey man (vramananx), you did a great job.  But, I have the same instance only for one board so far, for the rest works fine.
    E- *Error* rexExecute: argument #1 should be either a string or a symbol (type template = "S") - nil
    Please help, it would greatly benefit to our team's happiness.
  • joh17ny
    joh17ny over 11 years ago
    Hi vramanan,
    Do you have a skill file that will look for a single text?
     Johnny
