  3. Detected Layer-to-Layer Polygons that overlap
  • Replies 17
  • Subscribers 168
  • Views 30315
maxwellj
maxwellj over 16 years ago
I was wondering if anyone has a routine that goes in and lists all polgyons that overlap each other on a layer to layer basis.  We've been directed to find a way to check all our layers 1-2, 2-3, 3-4, .... and note any voltage polygons that overlap each other and then give them a percentage of overlap for each shape.  It's overkill, but these people have no other work to do, so they make new work for us.  Any help would be appreciated.
  • aCraig
    aCraig over 16 years ago
    I just tried to post some SKILL code to do this. But the moderator stop the post. Let me know if you'd like it send to you personally.
    Craig
  • maxwellj
     Craig-
     I would appreciate any help you could provide.  My email is my forum name  @nc.rr.com and anything you could offer would be apprecaited.
     Joe
  • vramanan
    vramanan over 16 years ago
    mike1coppercad said:
    Why do you need to measure the overlap?
     Just wondering...
    In 48V design  you want to avoid any digital signals or GND overlap w.r.to 48V signals
    Any 48V noise picked up by digital signals will make false triggers and signal integrity nightmares
     and the Z gap is  to make sure that 48V signals are isolated by enogh margin
    regards
    Venkata
  • vramanan
     Craig
    I would appreciate your inputs on this
    please send me the example code to me at vramanan @ infinera.com
    regards
    Venkata
  • maxwellj
     Mike-
    We're using some 1-ply material on our board due to the number of layers and a limited board thickness for mechanical reasons.  Our design coucil demands 2-ply at a minimum, but we can't do it because of physical size constraints.  They demand we provide all the poylgons (power) that cross so if there is a void in the material, they can assign probabilities to the chances of the board smoking. Yeah, I'm giggling here, too. :)   Truth is stranger than fiction.  This council has no technical knowledge, so our effort will be doubled to get it approved.
     joe
