  3. How To Get And Set Global Dynamic Shape Parameters By Using...
  • Replies 7
  • Views 11391
How To Get And Set Global Dynamic Shape Parameters By Using SKILL?
MaHongbing
MaHongbing over 16 years ago
    All, When I Open The Artwork Control Form To Setup The General Parameters In PCB Editor, The System  Always Required To Confirm "Artwork output type (GERBER6X00) does not match the format used in dynamic shapes parameters (GERBER_RS274)....". And My Question is "How To Get And Set Global Dynamic Shape Parameters By Using SKILL?" Thanks.
  • DE202408202727
    DE202408202727 over 13 years ago
    One way might be to use axlExportXmlDBRecords to dump the parameter groups and then look through the dynfill_parm_type section.
  • edaMac
    edaMac over 13 years ago
    Thanks! I'll check this one. May I also know the other ways to get this value? Thank you very much
