  3. how to remove a subclass
  • Replies 10
  • Subscribers 167
  • Views 23749
Ejlersen
Ejlersen over 16 years ago
Hi
I've been looking all over for an axl function to delete a subclass - but I've not been able to find such a function.
Can anyone help me?
Best regards
Ole
  • DE202408202727
    DE202408202727 over 13 years ago
    Use  axlSubclasses to list all subclasses for a class.
    Use axlLayerGet to get the layer parameters. The userDefined attribute tells you whether it is user-defined
    Use the selection set  utilities to see if it's empty
  • serpens
    serpens over 13 years ago
    This look use full, thanks too :)
  • VijayVela
    VijayVela over 13 years ago
    Hi Dave,
    Thanks for the guide. I managed to write a SKILL program to do this. One of my first program.. I'm pretty sure this code can be further simplified so realy appreciate your comments. Below is my code:-
    defun( cleanupSubclass ()
     l_sclass_to_delete = tconc(nil "SMART")
     l_filter = list("noall" "lines" "shapes" "linesegs" "shapesegs" "voidsegs" "figures" "text")
     l_visibility=axlVisibleGet() ;To store the currnet visibility
     axlSetFindFilter(?enabled l_filter ?onButtons l_filter)
     foreach( _subclass axlSubclasses("PACKAGE GEOMETRY" ?field 'userDefined)  ;Check every user defined subclass
      axlClearSelSet()
      axlVisibleDesign(nil)
      axlVisibleLayer(strcat("PACKAGE GEOMETRY/" _subclass) t )
      axlUIWUpdate(nil)
      axlAddSelectAll()
      aChkEmpty = length(axlGetSelSet())
      if( aChkEmpty > 0 then
       ; DO NOTHING AS THE SUBCLASS IS NOT EMPTY
      else
       if( substring(_subclass 1 3) == "DTS" then
        ; do nothing is there is a DTS prefix which is being used in our process
       else
        ;APPEND THE CLASS/SUBCLASS INTO THE LIST
        scls = strcat("PACKAGE GEOMETRY/" _subclass)
        tconc(l_sclass_to_delete scls)   ;append it into a list in the <class/subclasss> format
       ) ;end if
      ); end if
     );end foreach
     axlClearSelSet()
     axlSetFindFilter(?enabled 'noall ?onButtons 'noall)
     deleteUnusedSubclass(cdr(car(l_sclass_to_delete)))
     axlVisibleSet(l_visibility)
     axlUIWUpdate(nil)
    )  ; end defun
    defun( deleteUnusedSubclass (l_delSubCls)
     foreach( sclsToDelete l_delSubCls  ;delete every user defined subclass which are empty
      axlDeleteObject(axlLayerGet(sclsToDelete))
     );end foreach text items
    ); end defun
  • DE202408202727
    This is somewhat simpler:
     let((l_filter, l_visibility, layerName)
    l_visibility = axlVisibleGet() ;To store the currnet visibility
    axlClearSelSet()
    axlUIWUpdate(nil)
    axlAddSelectAll()
    unless(axlGetSelSet() || substring(_subclass 1 3) == "DTS"
    ;Delete the layer
    layerName = strcat("PACKAGE GEOMETRY/" _subclass)
    when(axlUIYesNo(sprintf(nil, "Delete layer: %s", layerName), nil, 'no)
    axlDeleteObject( axlLayerGet(layerName) );add it into a list in the <class/subclasss> format
    ) ;end unless
    );end foreach
    axlClearSelSet()
    axlUIWUpdate(nil)
    ))  ; end defun
  • VijayVela
    Thanks Dave...
