  3. getting netschedule type using skill?
  • Subscribers 160
  • Views 13291
Ejlersen
Ejlersen over 15 years ago
Hi
Do anyone know if there is a way to check if a nets/xnets schedule is set to "UserDefined" or "Template"?
Best regards
Ole
  • leonlee
    leonlee over 15 years ago
    Hi Ole,
    I'd like to share you a way to check the Nets' Rat Ts status. I'm not sure that it's same as your question of net schedule.
    Below command can get a list for those nets, which user defined the net schedule. It returns nil if without Rat Ts.
    setof(item, axlDBGetDesign()->nets, item->ratT)
    Leon
  • leonlee
    To check a net/xnet's net_schedule list:
    schedule_list = setof(item, net_dbid->ratsnest, item->userDefined)
    If schedule_list != nil, it indicates the net has UserDefined schedule.
