  3. How To Close a Polygon
  • Subscribers 160
  • Views 14041
raniv
raniv over 15 years ago
Is there a way to close a polygon without using chamfer or fillet?
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    How about shape->compose shape? Maybe you need to use shape->change shape type afterwards to make it unfilled.
    Otherwise, you could maybe use edit->z-copy
    Best regards
    Ole
  • Ejlersen
    Hi
    Forgot to mention that if you're doing a polygon using skill, you can close it using the command axlDBCreateShape
    Best regards
    Ole
  • raniv
    Thanks..
