  3. implementing a Dynamic Form
  • Subscribers 160
  • Views 14385
aeris
aeris over 15 years ago
how do we implement dynamic forms in Skill, similar with the Grids Form or Edit Property Form, i've checked the help file but no sufficient example for this, only given are the FIXED type
I need this to solve some problems that user encounter when using Long forms
I have also tried contacting our Allegro Reprensentative but they just suggested in using the TABSET
 thanks
  • aeris
    still no answer?
  • eDave
    eDave over 15 years ago
    I don't think that you can currently do it the way you want.
    The best idea may be to dynamically create your form and restrict the size based on the user requirements. Maybe you could check their screen size before creating the form.
    Dave
  • aeris
    I'm just curious how the Grid Form implement its form, same with the Edit Property form
    Both have a standard size form, and controls are added in a somewhat scrollable "panel"
    thanks
  • Fred06
    Fred06 over 15 years ago
    I have an exemple but i don't no if it's ok !!! please send me a Mail i will send the cadence exemple.
  • fxffxf
    fxffxf over 15 years ago
     These type of forms (VARTILES) are not supported in Skill. You should use the GRID control.
