  3. export pinlist to text file
  • Subscribers 160
  • Views 14891
Chinnu123
Chinnu123 over 15 years ago
Can any one tell me where I can get  Allegro Names for the following input pinlist for outputting to ASCII (.txt) using extracta command
NETNAME
COMPONENTS
TRANSMITTER CHANNEL
RECEIVER TESTERCHANNEL
TRANSMITTER PIN NAME
RECEIVER PIN NAME
TRANSMITTER LENGTH
RECEIVER LENGTH
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    Do you have an example file showing what you should get, It's not clear for me what you're aiming at.
    Ole
  • Chinnu123
    Thanks.I am looking for following output from allegro
    NETNAMECOMPONENTSTX TESTERCHANNELRX TESTER CHANNELTX PIN NAMERX PIN NAMETX LENGTHRX LENGTH
    BIST_ENABLER90.1J78.CS11 J78_PIN91 8269.52
    BMCINITR98.1J78.CS2 J78_PIN107 9196.25
    CATERR_NR83.1J78.AS2 J78_PIN112 8725.16
    CPU_ONLY_RESETR88.1J78.AS3 J78_PIN114 8899.66
    DDR_RESET_C01_N J80.DS6 J80_PIN14 8127.88
    DDR_RESET_C23_N J80.DS4 J80_PIN16 8274.08
    DDR_SCL_C01R73.1J78.DS1 J78_PIN110 9522.14
    DDR_SCL_C23R74.1J79.BS2 J79_PIN67 8082.64
    DDR_SDA_C01R75.1J78.CS6 J78_PIN101 8538.8
    DDR_SDA_C23R76.1J79.BS5 J79_PIN73 8530.22
  • Ejlersen
    Hi
    That's a tough one, how would the system know this is what you want? There are ton's of possibilities as I see it
    1. should the report show all signals or what is the criteria
    2. how does it determine what component and/or pin to add to the different fields
    Best regards
    Ole
