  3. shape creation
  • Subscribers 160
  • Views 13439
shape creation
kabalee
kabalee over 15 years ago
hi all,
when  i creating shape pad which one i will take example shape->filledshape  or rectangle or polygon
and when i created shape means offset value is arise when i import in pad designer...
warning is generated please suggest my problem
  • Nagaraj Shanmu
    Nagaraj Shanmu over 15 years ago
    Keep your shape center at the origin.
    Move the shape, using option tab select the pickup point as ‘body center’ and place at coordinate 0,0.
    Good luck
    Nagaraj
  • kabalee
     thank you for your information
    how to create custom pad and how to use it in footprint creation.please tell
  • HANUMAGOUDA
    HANUMAGOUDA over 15 years ago
    hi nagaraj, i am doing pcb designing for one of my circuit , how to create the foot print for the transistor Q2N4063 which is is required for my designing. reply me please. Thanking you. Warm regards, Hanumagouda Patil
  • Nagaraj Shanmu
    Carry out the below steps
    -          create the pad-stack using pad designer save this pad-stack and map the padstack created path to ‘padpath’ in userpereference->paths->library
    -          create the footprint using PCB librarian/PCB editor,save this results in .dra and psm file, include this symbol path in ‘psmpath’ in userpereference->paths->library
    If you are new to footprint creation read through Allegro User Guide: Defining and Developing Libraries
    Good luck!!
    Nagaraj
