  3. axlOKToProceed
  • Subscribers 160
  • Views 13265
axlOKToProceed
Khurana
Khurana over 15 years ago
Using Allegro Skill, I’d like to know how to check to see whether Allegro PCB Editor is in the middle of a command such as Edit > Move…I looked in the Allegro Skill User Guide and looks like axlOKToProceed would work but it’s not working for me and I'd like to know if there’s a better way to do this OR there's a fundamental problem in my code (below)?
Below is the text which shows how I am currently using axlOKToProceed…blah1 and blah2 statements are still getting executed even when okProceed is null.  When okProceed is null, then I’d like axlUIConfirm to get executed, and it’s not.
Varun
axlCmdRegister("dtext" 'decreaseText ?cmdType "general")
(defun decreaseText ()
                (prog (okProceed)
                okProceed = axlOKToProceed()
                if(okProceed
                then
                                blah1
                                blah2
                else
                                axlUIConfirm(“Blah Blah”)
                ); end if
                ); end prog
); end defun
  • oldmouldy
    oldmouldy over 15 years ago
    The documentation for axlOKToProceed appears to be ambiguous in that it is implied to be a function but, if you check the examples, axlSetFindFilter for instance, it looks like it is actually used as a variable. Try copying the mechanism used in the axlSetFindFilter documentation and see if your routine will then work as expected.
  • Helen
    Helen over 14 years ago
    It is not about "if" it is about "when".
    (when axlOKToProceed
        ;; do AXL interactive command
