  3. Skill to check minimum cline segment
  • Replies 24
  • Subscribers 166
  • Views 32898
Alice 2009
Alice 2009 over 16 years ago
I am trying to write an skill to check cline segment length and show DRC if it violate the minimum cline segment.
Does anyone have similar skill that I can refer? please share.
Alice.
  • DE202408202727
    DE202408202727 over 16 years ago
    Hi Alice,
    Well, there's a lot wrong with your code. I've corrected enough to get you going again.
    I'm not sure what you are trying to do with the popup.
    Keep at it and good luck!
    Dave
    mincline_drc.zip
  • Alice 2009
    Hi Dave, I managed to modified the script and get correct DRC. Thanks a lot for the help.
    Alice
  • PAVANRKS
    PAVANRKS over 13 years ago
    Hi Dave,
    if run my minmu cline drc skill means this below error coming.
    E- Command not found: mincline_drc
    Good Day,
    Pavan Kumar Kulkarni
  • PAVANRKS
    Hi Alice,
    Can you share your .il for minimum cline segment.
    Good Day,
  • DE202408202727
    DE202408202727 over 13 years ago
    Hi Pavan,
    If you are getting that error message then you are running the command in the wrong place. Type it in the skill window or prefix it with "skill "
    Dave
