  3. Skill to check minimum cline segment
  • Replies 24
  • Subscribers 161
  • Views 27876
Alice 2009
Alice 2009 over 15 years ago
I am trying to write an skill to check cline segment length and show DRC if it violate the minimum cline segment.
Does anyone have similar skill that I can refer? please share.
Alice.
  • leonlee
    leonlee over 15 years ago
    Hi Alice,
     I'd like to share you the idea:
    MinL = 0.5 ; the minimum length you set
    axlVisibleLayer( "etch" t )
    axlClearSelSet()
    axlSetFindFilter( ?enabled "Clinesegs" ?onButtons "Clinesegs" )
    allClinesegs = axlGetSelSet( axlAddSelectAll())
    ;To get the violated cline segments, which length is less than your minimun value.
    violateSegs = setof( item, allClines, axlDBGetLength( item ) < MinL )
    Then you can use axlDBCreateExternalDRC to create DRC mark for eatch items in the list violateSegs.
    FYI.
    Leon
  • Alice 2009
    Hi Leon,
    Thanks for the idea. I manage to create the DRC. However, I still have some Q:-
    #1. Is there syntax to clear the DRC created by axlDBCreateExternalDRC() ? If not, any other manual way to remove created DRC?
    #2. Can I use a variable instead of actual value for the last argument of this axlDBCreateExternalDRC() ?
    axlDBCreateExternalDRC('("Minimum Cline Length" "50um") 1500:1900 "drc error class/layer2" nil nil variable)
    If not, is there a way to show the variable value in the DRC created?
    Alice
  • leonlee
    #1 To delete external DRC:
         axlDeleteObject(setof(item, axlDBGetDesign()->drcs, item->name=="Externally Determined Violation"))
    #2, Of course, you can use variant as the value.
    Try it~~
  • Alice 2009
    Hi Leon,
     When I use variable "clineLength" as show below, it gives me warning and the DRC did not appear. Please advise.
    clineLength=axlDBGetLength( item )
    axlDBCreateExternalDRC('("Minimum Cline Length" "50um") 1500:1900 "drc error class/layer2" nil nil clineLength)
    W- *WARNING* (axlDBCreateExternalDRC): Invalid string - 33.06258
    Alice
  • leonlee
    Hello Allice,
     It just need a string. You can replace a line to convert the variant into string:
       clineLength = sprintf( nil "%n" axlDBGetLength( item ) )
    Hope it works.
