  3. Ideas/Help Needed for Padstack Edit
  • Subscribers 159
  • Views 4268
archive over 15 years ago
Hi Guys I give up, I tried for a while and now I don’t know what to do This is what I want to do in Skill 1.  Load a Padstack 2.  Edit the pad-definition on only selected layers, either make them null or assign a new value I tried the following methods
Method 1:
 a.  Get All padstacks b.  Foreach padstack and foreach pad-definition make a copy of pad definition a.  Using make_axlPadStackPadb.  Modify the values if neededc.  Create a New Padstack  Replace the old padstack with new padstack
                Problem:
a.  Not able to create the pad-definition structure, error prone
Method 2:
a.  Foreach padstack I use axlDBCopyPadstack and trim it by specifying the start/end layerp1=axlLoadPadstack("CIR60D40")p2 = axlDBCopyPadstack(p1, '("CONDUCTOR/RDL_SEC" "CONDUCTOR/TOP_PRM"), t)axlPadstackToDisk(p2->name)
Problem:
a.  This doesn’t seem to work, the resulting padstack still has all the pad definition on the other layersb.  Trimming doesn’t seems to work
Method 3:
a.  Use Allegro Scripting all the way
Problem:
a.  Error Prone and there is no way to control occasional out of blue pop-ups  I am out of ideas and would appreciate any kind of help on this issue  Is there is any way I can load a padstack and go to a certain padstack definition on a given layer and change its vaule
regards
Vramanan
  • eDave
    eDave over 15 years ago
    Hi Vramanan,
    I believe that method 1 is the only one that will work well - and it does work.
    You need to define the pads for every layer using make_axlPadStackPad and then create the padStack using axlDBCreatePadStack before using axlPadstackToDisk.
    Works for me.
    Dave
    Hi Guys
    I was able to pull it off, here are my couple of my observation and hope it helps people who want's to go on this route
    First and foremost, understand and be aware of the the field mappings, for example
    if you are deriving values from an pad-def (padstackdbid->pads->pad) using make_axlPadstackPad then
    this is the mappig you have to follow
    dbid->pads->pad
    make_axlPadstackPad
    notes
    ?figure
    ?figureName
    ?figure
    Rectangle, shape, square*
    ?flash
    ?flash
    ?layer
    ?layer
    ?objType
    ?offset
    ?offset
    ?parent
    ?type
    ?type*
    Make ANTI to ANTIPAD
    ?bBox
    ?figureSize
    You have to derive the figure width and height
    ?readOnly
    ?name
    Make sure that you provide proper checks for figure names like rectangle, square, shape
     for square you should only one value for the figuresize
     similarly for make_axlPadStackDrill the arrival figureSize has to be correct
    there is no way to grab the drill tolerance, you have to find the plating status of the drill using the axl function axlDBGetDrillPlating
    plus if you are touching all the padstacks then I found out that axlReplacePadstack would take a tremendous amount of time since I am passing the dbids of all the pins for a particular padstack
    for a big design it woudl take hours
    my way of getting around it is I created the new instances of the padstacks i am modifying and use the allegro's refresh padstack list option
     for a test case i was able to do things in 90 secs from 5 minutes
     Hope this is helpful for people who is messing around with padstacks :-)
    regards
    Vramanan
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    As a kind of follow up on this it seems like the documentation for make_axlPadStackDrill (part of axlDBCreatePadStack) not has been updated.
    If I pull the record for a padstack I get a lot of more options than what is documented.
    Anyone know the most recent argument list for make_axlPadStackDrill and also if it is possible to change the slot symbol in this way? How can we get the complete parameter list for a function?
    The undocumented parameters at least are
    drillFigureHeight
    drillFigureWidth
    drillFigureName
    drillSizeHeight
    drillFigureName
    drillSizeHeight
    drillSizeWidth
    drillDiameter
    drillOffset (suppose this is what was offset, but has the name changed for the function?)
    (prop nil bBox
        ((-1.842 -1.842)
     (1.841 1.841)
        ) readOnly
        t pads
        (pad:200849088 pad:200849064 pad:200849040 pad:200849016 pad:200848992
     pad:200848968 pad:200848944 pad:200848920 pad:200848896 pad:200848872
     pad:200848848 pad:200848824 pad:200848800 pad:200848776 pad:200848752
     pad:200848728 pad:200848704 pad:200848680
        ) objType "padstack"
        startEnd
        ("ETCH/TOP" "ETCH/BOTTOM") parent dbid:189357224 name
        "HOLE110" drillChar nil plating "NON_PLATED"
        holeType "rectangle_slot" drillNonStandard nil multiDrillData
        nil uvia nil type "through"
        keepout nil holeTolerance
        (0.0 0.0) drillFigureHeight
        1.23 drillFigureWidth 2.794 drillFigureName "RECTANGLE"
        drillSizeHeight 1.23 drillSizeWidth 2.794 drillDiameter
        1.23 drillOffset
        (0.0 0.0) isThrough t
        definition nil isPadRef nil
    Best regards
    Ole
  • fxffxf
    fxffxf over 14 years ago
    The 16.5 the padstack dbid attributes are:
     Padstack Attributes:   padstacks in Allegro
        NAME                TYPE    DESCRIPTION
            Also includes generic object attributes
        definition          o_dbid  (see isPadRef) Points to padstack definition if this is
                                    padReference otherwise nil
        drillChar           string  drill characters (max 3)
        drillDiameter       float   Drill hole diameter (0 if slot)
        drillSizeWidth      float   width of slot, diameter if hole and extents of mulidrill
        drillSizeHeight     float   height of slot, diameter if hole and extents of mulidrill
        drillOffset         point   offset of drill hole
        drillFigureName     string  type of drill symbol (circle, square, etc.)
        drillFigureWidth    float   Width of drill symbol (for slots same as drillSizeWidth)
        drillFigureHeight   float   Height of drill symbol (for slots same as drillSizeHeight)
        drillNonStandard    string  Type of drill (nil is standard) (not supported by slots)
        holeTolerance       l_float A list of two numbers reporting the + and -
                                    drill hole tolerance
        multiDrillData      l_values If not multidrill then nil otherwise list
                                    of (rows columns clearanceX clearanceY
                                    staggered) both clearances are in dbreps
                                    and staggered is t/nil
        holeType            string  Type of hole (circle_drill, oval_slot, etc.)
        keepout             t/nil   Padstack built to accomodate anti-pads as
                                    Route keepouts for mechanical pins. This
                                    padstack can also be used for logical
                                    connections but this option is ignored.
        isPadRef            t/nil   t = padstack is a padstack reference. This means that the
                                    actual padstack is a template and the padstack's start
                                    end layers is dynamically mapped depending upon its
                                    use with a pin or via.
        isThrough           t/nil   t = through padstack
        name                string  Padstack name
        objType             string  Type of object, in this case "padstack"
        pads                ll_dbid List of pads
        parent              dbid    Design
        plating             string  One of "Plated", "Non-Plated", "Plating-Optional"
        prop                nil     Always nil, padstacks do not support properties
        startEnd            lt_layer Start and end layer of padstack
        type                string  Type of padstack; through, smd, bbvia, uvia
        uvia                t/nil   A sub-type of bbvias, to differentiate in
                                    constraint system.
  • Ejlersen
    Hi
    Thanks for that - a bit more comprehensive than the database model description and the axlDBCreatePadstack.txt description - I got some of them from enquiering the dbid - but the exact naming and types are good giveaways.
    Best regards
    Ole
