  3. Snap to object alias
  • Subscribers 159
  • Views 14943
LP2R4T
LP2R4T over 15 years ago
I would like to assign an alias Key to speed up the snap to pin menu selection when into a copy or move function. Please let me know..
  • Rik Lee
    Rik Lee over 15 years ago
     I'm not sure if this subject belongs in the SKILL section however...
    While moving an objectyou can use these function keys.
    You will need to add these to your ~/pcb/env file
    funckey f "prepopup;pop dyn_option_select 'Snap pick to@:@Figure'"
    funckey i "prepopup;pop dyn_option_select 'Snap pick to@:@Intersection'"
    funckey c "prepopup;pop dyn_option_select 'Snap pick to@:@Arc/Circle Center'"
    funckey v "prepopup;pop dyn_option_select 'Snap pick to@:@Via'
    funckey p "prepopup;pop dyn_option_select 'Snap pick to@:@Pin'
  • LP2R4T
    Thanks Rik,
     This is very helpful.
     I would also like to assign different Grids to function key. Is there a way to do that and have them into the env file?
     Thanks in advance
  • Rik Lee
    That can be accomplised by recording a script or scripts of the different grid settings and then assiging a function key to replay the script. e.g. funckey 5 "replay <script_path>\g5.scr"
    Cadence Online Support document
    11094134 goes into detail on this subject and expounds on how to add the scripts to the Allegro menu.
