  3. Skill code to evaluate all components area (Accumulative...
  • Views 20006
Skill code to evaluate all components area (Accumulative Place bound area)
Robyd
Robyd over 16 years ago
Hi I am starting a very small and dense design with many 0.5mm BGA's with BBV,About 1000 comps. I am afraid that the total available PCB area for component placement is not enough. Is there out there any Skill that sums up all components place bound area ? So I can compare it to board’s available placement area ? and not end up placement with components left outside the board ;-) BTW : There is a similar function inside the Mentor Expedition. Best Regards Roby
  • DE202408202727
    DE202408202727 over 16 years ago +1
    Hi. I have code that gives the absolute areas of top and bottom components and the ratio of board usage using the board outline - if it is a contiguous shape. I will need to take a minute to convert it…
  • Robyd
    Robyd over 16 years ago +1
    Hello eDave Yes Thank you. If it's not a big deal - Please sent or post it. Regards, Robyd
  • Robyd
    Hi Ole
    Yes, Thank you
    will it be hard to alter it to read BRD componets place bound areas and sum it up
    in order to compare to board area availiable for placement .
    following your post i came up with an idea
    during footprint creation adding a custom property to all place bound with their area
    In order to enable reporting and summing with allegro reports
    Do you think this idea can work ?
    Best Regards,
    Robyd
