  3. Need helps with the form grid table.
  • Subscribers 159
  • Views 13444
stillfish
stillfish over 15 years ago
Hi all,
I am trying to create a grid table to put my data list that each data has lots of column fields. I have set each field's column width with the total column width is larger than the grid table size I set in the form file. I supposed that there is a horizontal slide bar under the table and I can browse table by moving the slide bar. But it does not work as i figured, the table seems to auto adjust all its fields column width to fit the grid table size.
And then I could not really fix my field width to show datas prettily. Or I have to manually adjust each field every time.
Has anyone also have the same problem?
Here is brief code:
In form file:
  GRID gridtable
  FLOC 25 4
  FSIZE 110 15                   ; grid table has width 110
  OPTIONS HLINES VLINES USERSIZE
  ENDGRID
Main function:
  axlFormCreate('Qfm_vios_form G_vios_form '("E" "OUTER") 'QviosViewerFormAct t)
  Q_ViosGridInitHeader()
  ;insert items
  axlFormGridInsertRows(Qfm_vios_form "gridtable" 0 25)
  axlFormGridSetBatch(Qfm_vios_form "gridtable" 'QViosGridInsertRowsCB nil)
  axlFormGridUpdate(Qfm_vios_form "gridtable")
  axlFormDisplay(Qfm_vios_form)
defun(Q_ViosGridInitHeader ()
  let((default_header)
    default_header=list(
      list("ID" 'LONG 15 15)
      list("Module" 'STRING 30 35)
      list("Type" 'STRING 25 30)
      list("Name" 'STRING 25 35)
      list("Sub Name" 'STRING 25 35)
      list("Class" 'STRING 25 35)
      list("Sub Class" 'STRING 25 35)
      list("Expect Value" 'REAL 10 20)
      list("Actual Value" 'REAL 10 20)
      list("Delta" 'REAL 10 20)
      list("Comment" 'STRING 40 80)
    foreach(it default_header
      col = make_formGridCol()
      col->headText = car(it)
      col->fieldType = cadr(it)
      col->colWidth = caddr(it)               ; I want that the display width is exactly equal this value
      col->fieldLength = cadddr(it)
      axlFormGridInsertCol(Qfm_vios_form "gridtable" col)
    );end for
defun(QViosGridInsertRowsCB (trash)
  let((cell nRows nField)
    ;this is a test data
    G_ViosList=list(list(
      12345678 "this is a test module 30 chars" "1234567890123456789012345"
      "1234567890123456789012345" "1234567890123456789012345" "1234567890123456789012345"
      "1234567890123456789012345" 123456.789 123456.789 123456.789
      "a long comment"
    cell = axlFormGridNewCell()
    nRows=0
    foreach(item G_ViosList
      nRows++
      cell->row=nRows
      nField=1
      foreach(item_f item
        cell->col = nField
        cell->value=nth(nField-1 item)
        axlFormGridBatch(cell)
        nField++
