  3. S parameter model for PCB SI
  • Subscribers 161
  • Views 16821
ajayd
ajayd over 15 years ago
Could anybody tell me how can i use s-parameter model for modelling my connectors. For back-plane connectors model i want to use s-parameter model instead of ibis model (.dml file). I am using Allegro PCB SI 15.5.
  • oldmouldy
    oldmouldy over 15 years ago
    You will need a PCB SI 630 license to use S Parameters. The S Parameter models need to be converted to DML, take a look at the Model Integrity User Guide, miug.pdf in the doc\miug directory of the installation, page 24 "Converting and Normalizing Touchstone Files"
  • ajayd
    Thanks Oldmouldyfor your reply.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    Depending on your needs you could also add the S-Parameters Option to a lower level tool than 630
    Look at page 5-6 for the needed functionality at http://www.cadence.com/rl/Resources/datasheets/pcb_signal_ds.pdf
    Best regards
    Ole
  • ajayd
    ajayd over 14 years ago
     I have S-parameter model of "connectors". When I tried converting them to DML it gave error
    "Error: The first statement line must be .subckt " . What's the reason for this. Kindly send me a link where S-parameter to DML conversion is explained nicely. I am using PCB SI 16.2/XL.
    Ajay
  • ajayd
     It would be great help if someone can reply to the post. I am not able to convert S16P file to DML using model integrity. I am using PCB SI GXL also.
    Thanks and regards
    Ajay
