  3. Form with
  • Replies 11
  • Subscribers 160
  • Views 18093
Form with
LP2R4T
LP2R4T over 15 years ago
How can I create a form with a fillin field that accepts multiple decimal values similar to the Grid spacing Setup menu in APD.
Spacing x: 25.00 25.00 25.00
now the formfield looks like this:
FORMFILE FIELD current_grid_x_grids
FORMFILE FLOC 30 4
FORMFILE STRFILLIN 30 256
FORMFILE ENDFIELD
The problem is that it accepts all string values..
Thanks in advance
  • eDave
    eDave over 15 years ago
    Use REALFILLIN not STRFILLIN
  • LP2R4T
    Takes Dave
    But What I want to acheive is to be able to have more then one real number in the same Field.Similar to the Grid Setup menu.
    Regards
  • fxffxf
    fxffxf over 15 years ago
    REALFILLIN supports a single double precision number but if you require multiple numbers to be entered into a single field, you need to declare it to be a STRFILLIN, parse the input and use one of the family of axlMKSxxx APIs to convert the each resulting string value to a number.
  • LP2R4T
    Thanks I'll try that
  • LP2R4T
    What would be the solution to limit the inputs of the Strfillin Field to accept only numerical values in order to avoid having text.
