  3. Wrong Time
  • Subscribers 159
  • Views 14111
Wrong Time
aeris
aeris over 15 years ago
anyone knows whats causing the wrong Time from this skill API
getCurrentTime()
its giving me this : "Dec 09 01:15:33 2010"
while the correct time is around 9 AM
not sure if I messed up some settings in Allegro
thanks
  • eDave
    eDave over 15 years ago
    That looks like GMT (Greenwich Mean Time) or UTC. You might want to check your PC time zone settings.
  • aeris
    Hi Dave
    is that where we double click on the time in the lower right portion of our monitor, but then i just select the country where i'm from..
     thanks
  • eDave
    Yes. That should do it.
  • aeris
    still no go..
  • aeris
    for those encountering same problem, you can
    1. Check if you have installed any application related to Time, and double check if it was correctly configured or sync with your local time zone
    2. Check whether you have a "TZ" system variable, -- disable or rename this variable --, you may need to watch out for any app that uses this
