  3. Silk Rotate skill file
  • Replies 23
  • Subscribers 169
  • Views 34780
Jocko
Jocko over 15 years ago
I have this old skill program, RotateSilkAssyRD.il. Its a great tool to get ref des align, re-sized and reset to start
working on cleanup.  I've used it on 15.7, but now on 16.1 and 16.3 I get an error.
When I envoke the skill I get this error.
E- *Error* fprintf: argument #1 should be an I/O port (type template = "ptg") - nil
Not sure where I got it and when, I may have stripped out the authors name in the past.
A great time saver when your working with a lot of parts.
;#   Rotate Reference Designator Text on Silkscreen and Assembly Layers    #
;#  This routine rotates Silkscreen and Assembly Reference Designators     #
;#  such that they are all "rightward reading".  This means that all RDs   #
;#  will read left to right if they are horizontal, or bottom to top if    #
;#  they are vertical.                                                     #
;#  Additionally, any Assy RD will automatically be moved to the component #
;#  origin.        #
;#  Usage:  rotate_silkassy (from within Allegro)                          #
;#  Register Program Name #
axlCmdRegister("rotate_silkassy" 'RotateSilkAssyRD)
;# MAIN Program Starts Here. #
(defun RotateSilkAssyRD ()
  ; ==== Initialize Global Variables ====
  Layer_List = nil
  Text_List  = nil
  Layer_List = nil
  justify    = ""
  LRBT = t   ; Left to Right, Bottom to Top
  LRTB = nil ; Left to Right, Top to Bottom
  RLBT = nil ; Right to Left, Bottom to Top
  RLTB = nil ; Right to Left, Top to Bottom
  CenterAssy = t
  ChangeTextSize  = nil
  TextBlockLarge  = 6
  TextBlockMedium = 3
  TextBlockSmall  = 1
  tblk_large  = "6"
  tblk_medium = "3"
  tblk_small  = "1"
  SilkTop = nil
  SilkBot = nil
  AssyTop = nil
  AssyBot = nil
  silktop_layer = "REF DES/SILKSCREEN_TOP"
  silkbot_layer = "REF DES/SILKSCREEN_BOTTOM"
  assytop_layer = "REF DES/ASSEMBLY_TOP"
  assybot_layer = "REF DES/ASSEMBLY_BOTTOM"
  sym_savex  = -1
  sym_savey  = -1
  sym_saveparent = nil
  SetupDir()
  if( axlOKToProceed() then
      ; ==== Create and Display the User Interface ====
      createRotateRDForm()
      fFile = strcat( FormDir "rotateRDForm.form" )
      Form = axlFormCreate( (gensym)  fFile  nil 'rotateRDForm_Action t)
      axlFormSetField(Form "LRBT" LRBT)
      axlFormSetField(Form "LRTB" LRTB)
      axlFormSetField(Form "RLBT" RLBT)
      axlFormSetField(Form "RLTB" RLTB)
      axlFormSetField(Form "CenterAssy"      CenterAssy)
      axlFormSetField(Form "TextBlockLarge"  TextBlockLarge )
      axlFormSetField(Form "TextBlockMedium" TextBlockMedium)
      axlFormSetField(Form "TextBlockSmall"  TextBlockSmall )
      axlFormDisplay( Form )
  else
      printf("E- Please terminate your interactive command .\n")
  );endif OKToProceed
); end defun - MAIN Program
;# doRotateSilkAssy - When OK is hit, perform Reference Designator Rotation #
;#                   Do each layer separately to improve performance.       #
(defun doRotateSilkAssy ()
   axlClearSelSet()
   axlSetFindFilter( ?enabled   (list "noall"  "text")
                     ?onButtons (list "text")
   axlMsgPut("Silk/Assy RD rotation started.")
   foreach( layer Layer_List
            axlVisibleDesign(nil)
            axlVisibleLayer( layer t)
            Text_List = axlGetSelSet( axlAddSelectAll() )
            if( length( Text_List ) != 0 then rotateSilkAssy() )
            axlClearSelSet()
            axlFlushDisplay()
            axlMsgPut(strcat( layer " Rotation completed.") )
          ); foreach
; ==== Turn On Top/Bottom Silk & Assembly Layers, if they were changed. ====
   Display_List = list("paramLayerGroup:BOARD GEOMETRY/paramLayer:OUTLINE")
   if( AssyTop == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:ASSEMBLY_TOP" Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:ASSEMBLY_TOP"          Display_List)
   if( AssyBot == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:ASSEMBLY_BOTTOM" Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:ASSEMBLY_BOTTOM"          Display_List)
   if( SilkTop == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:SILKSCREEN_TOP"  Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:SILKSCREEN_TOP"           Display_List)
   if( SilkBot == t then
       Display_List = cons("paramLayerGroup:PACKAGE GEOMETRY/paramLayer:SILKSCREEN_BOTTOM" Display_List)
       Display_List = cons("paramLayerGroup:REF DES/paramLayer:SILKSCREEN_BOTTOM"          Display_List)
   foreach( Layer Display_List
            val = axlGetParam( Layer )
            val->visible = t
            axlSetParam( val )
); end defun - doRotateSilkAssy
;# rotateSilkAssy - Check layer type, Get RD Coordinates and rotation.#
;#                  Rotate RD in place if wrong orientation, change   #
;#                  text justification to "center".                   #
(defun rotateSilkAssy ()
   foreach( text_id Text_List
            ;axlMsgPut(strcat("Processing: " text_id->text))
            ; ==== retrieve current information on text id              ====
        changeit = 0
        text   = text_id->text
        xy     = text_id->xy
            txt_x  = xCoord( xy )
            txt_y  = yCoord( xy )
            txt_tblk = text_id->textBlock
        ; ==== Change Text to "Center" Justification for ease of use ====
            txt_jus= text_id->justify
            if( txt_jus != "CENTER" then changeit = 1 )
        ; ==== Check current rotation against preferred orientation ====
              ; ==== Change if necessary                                  ====
        txt_rot= text_id->rotation
            if( LRBT == t then
                if( txt_rot == 180 then
                    txt_rot  = 0
              changeit = 1
                if( txt_rot == 270 then
                    txt_rot  = 90
              changeit = 1
              );endif LRTB
        if( LRTB == t then
                    txt_rot  = 0
              changeit = 1
                if( txt_rot == 90 then
                    txt_rot  = 270
                    changeit = 1
              );endif LRBT
        if( RLBT == t then
                    txt_rot  = 0
                    changeit = 1
                    txt_rot  =  90
                    changeit = 1
              );endif RLBT
        if( RLTB == t then
                    txt_rot  = 0
                    changeit = 1
                    txt_rot  = 270
                    changeit = 1
              );endif RLTB
              ; ==== ON Assembly Layers, if requested by user in form ====
            ; ====    Move Assy Text to Calculated Symbol origin    ====
            ; ====    Change Text Block Sizes for easier reading.   ====
            txt_lyr = text_id->layer
            if( txt_lyr == assytop_layer || txt_lyr == assybot_layer || txt_lyr == silktop_layer || txt_lyr == silkbot_layer then
                if( CenterAssy == t then
                    foreach(childid text_id->parent->children
                            if( childid->layer == "PACKAGE GEOMETRY/PLACE_BOUND_TOP" ||
                                childid->layer == "PACKAGE GEOMETRY/PLACE_BOUND_BOTTOM" then
                                sym_llx = xCoord( xCoord( childid->bBox ))
                                sym_lly = yCoord( xCoord( childid->bBox ))
                                sym_urx = xCoord( yCoord( childid->bBox ))
                                sym_ury = yCoord( yCoord( childid->bBox ))
                                sym_x   = (sym_urx + sym_llx) / 2
                                sym_y   = (sym_ury + sym_lly) / 2
                              );endif childid
                           );end foreach
                    if( txt_rot ==   0 then sym_y = sym_y - 20 )
                    if( txt_rot ==  90 then sym_x = sym_x + 20 )
                    if( txt_rot == 180 then sym_y = sym_y + 20 )
                    if( txt_rot == 270 then sym_x = sym_x - 20 )
                    xy       = list( sym_x sym_y )
                    changeit = 1
                  );endif CenterAssy
                if( ChangeTextSize == t then
                    changeit = 1
                    txt_tblk = tblk_large
                    rdalpha  = substring( text 1 1 )
                    if( rdalpha == "C" || rdalpha == "R" then
                        txt_tblk = tblk_small
                    if( rdalpha == "D" then
                    rdalpha  = substring( text 1 2 )
                    if( rdalpha == "RN" || rdalpha == "RP" then
                        txt_tblk = tblk_medium
                if( rdalpha == "FB" || rdalpha == "KP" then
              if( rdalpha == "TP" then
                  );endif ChangeTextBlock
              );endif txt_lyer
          ; ==== Do text movement, if anything has changed ====
;VAN HUYNH modified here (add _RD)
            if( changeit == 1 then createTextBlock_RD())
      ); endforeach
); end defun - rotateSilkAssy
;# createTextBlock - Create text record and write information to    #
;#                   the database.                                  #
(defun createTextBlock_RD ()
  textBlock = txt_tblk
  rotation  = txt_rot
  parent_id = text_id->parent        ; symbol association
  mirrored  = text_id->isMirrored    ; t/nil
  justify   = "CENTER"               ; "LEFT" "CENTER" "RIGHT"
  ; ==== setup defstruct for text insertion ====
  textOrientation = make_axlTextOrientation( ?textBlock textBlock,
                                             ?rotation  rotation,
                                             ?mirrored  mirrored,
                                             ?justify   justify
  ; ==== Add new text and delete the existing text if successful ===
  update = axlDBCreateText( text, xy, textOrientation,
                            text_id->layer, parent_id
  if( update != nil then
    ; axlMsgPut("Update Succeeded.")
      axlDeleteObject( list( text_id ))
  else
      axlMsgPut( strcat( "Update Failed on " text ) )
    ); endif
); end defun - createTextBlock_RD
 ;# Form CallBacks - Determine Allegro command to execute   #
 ;#                  based on the user's selection          #
(defun rotateRDForm_Action (Form)
   (case Form->curField
     ("SilkTop"
        SilkTop=Form->curValue
     ); end "SilkTop"
     ("SilkBot"
        SilkBot=Form->curValue
     ); end "SilkBot"
     ("AssyTop"
        AssyTop=Form->curValue
     ); end "AssyTop"
     ("AssyBot"
        AssyBot=Form->curValue
     ); end "AssyBot"
     ("LRBT"
        LRBT=Form->curValue
        orient_0   = t
        orient_90  = t
        orient_180 = nil
        orient_270 = nil
     ); end "LRTB"
     ("LRTB"
        LRTB=Form->curValue
        orient_0   = t
        orient_90  = nil
        orient_180 = nil
        orient_270 = t
     ); end "LRTB"
     ("RLBT"
        RLBT=Form->curValue
        orient_0   = nil
        orient_90  = t
        orient_180 = t
        orient_270 = nil
     ); end "LRTB"
     ("RLTB"
        RLTB=Form->curValue
        orient_0   = nil
        orient_90  = nil
        orient_180 = t
        orient_270 = t
     ); end "LRTB"
     ("CenterAssy"
        CenterAssy=Form->curValue
     ); end "CenterAssy"
     ("ChangeTextSize"
        ChangeTextSize=Form->curValue
     ); end "ChangeTextSize"
     ("TextBlockLarge"
        TextBlockLarge=Form->curValue
        sprintf( tblk_large "%L" TextBlockLarge )
     ); end "TextBlockLarge"
     ("TextBlockMedium"
        TextBlockMedium=Form->curValue
        sprintf( tblk_medium "%L" TextBlockMedium )
     ); end "TextBlockMedium"
     ("TextBlockSmall"
        TextBlockSmall=Form->curValue
        sprintf( tblk_small "%L" TextBlockSmall )
     ); end "TextBlockSmall"
     ("done"
        ; ==== cons puts the list together in reverse order
        if( AssyBot == t then Layer_List = cons( assybot_layer Layer_List ) )
        if( AssyTop == t then Layer_List = cons( assytop_layer Layer_List ) )
        if( SilkBot == t then Layer_List = cons( silkbot_layer Layer_List ) )
        if( SilkTop == t then Layer_List = cons( silktop_layer Layer_List ) )
        doRotateSilkAssy()
        (axlFormClose Form)
        (axlCancelEnterFun)
        deleteFile( fFile )
     ); end "done"
     ("cancel"
        (axlFormClose Form)
        (axlCancelEnterFun)
        deleteFile( fFile )
     ); end "cancel"
   ); end case
 ); end defun - rotateRDForm_Action
  ;# End Form CallBacks    #
  ;# createTitleBlockForm - Main User Interface Form         #
  ;#                        Brought up by executing command. #
(defun createRotateRDForm ()
   Form  = outfile( fFile "w")
   fprintf(Form "FILE_TYPE=FORM_DEFN VERSION=2\n")
   fprintf(Form "FORM\n")
   fprintf(Form "FIXED\n")
   fprintf(Form "PORT 77 20\n")
   fprintf(Form "HEADER \"Rotate Silkscreen/Assembly Reference Designators V2.0\"\n")
   fprintf(Form "TILE\n")
   fprintf(Form "GROUP \"Select Layers to Rotate\"\n")
   fprintf(Form "GLOC 2 1\n")
   fprintf(Form "GSIZE 72 4\n")
   fprintf(Form "ENDGROUP\n")
   fprintf(Form "FIELD \"SilkTop\"\n")
   fprintf(Form "FLOC 3 3 \n")
   fprintf(Form "CHECKLIST \"Silkscreen-Top\" \n")
   fprintf(Form "ENDFIELD\n")
   fprintf(Form "FIELD \"SilkBot\"\n")
   fprintf(Form "FLOC 20 3 \n")
   fprintf(Form "CHECKLIST \"Silkscreen-Bottom\" \n")
   fprintf(Form "FIELD \"AssyTop\"\n")
   fprintf(Form "FLOC 37 3 \n")
   fprintf(Form "CHECKLIST \"Assembly-Top\" \n")
   fprintf(Form "FIELD \"AssyBot\"\n")
   fprintf(Form "FLOC 54 3 \n")
   fprintf(Form "CHECKLIST \"Assembly-Bottom\" \n")
   fprintf(Form "GROUP \"Select RD Orienation\"\n")
   fprintf(Form "GLOC 2 5\n")
   fprintf(Form "GSIZE 32 13\n")
   fprintf(Form "GROUP \"Ref Des Alterations\"\n")
   fprintf(Form "GLOC 36 5\n")
   fprintf(Form "GSIZE 38 13\n")
   fprintf(Form "TEXT \"Horizontal           Vertical \"\n")
   fprintf(Form "TLOC 6 7 \n")
   fprintf(Form "ENDTEXT\n")
   fprintf(Form "FIELD \"LRBT\"\n")
   fprintf(Form "FLOC 3 9 \n")
   fprintf(Form "CHECKLIST \"Left to Right     Bottom to Top\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"LRTB\"\n")
   fprintf(Form "FLOC 3 11 \n")
   fprintf(Form "CHECKLIST \"Left to Right     Top to Bottom\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"RLBT\"\n")
   fprintf(Form "FLOC 3 13 \n")
   fprintf(Form "CHECKLIST \"Right to Left     Bottom to Top\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"RLTB\"\n")
   fprintf(Form "FLOC 3 15 \n")
   fprintf(Form "CHECKLIST \"Right to Left     Top to Bottom\" \"rotate_group\" \n")
   fprintf(Form "FIELD \"CenterAssy\"\n")
   fprintf(Form "FLOC 37 7 \n")
   fprintf(Form "CHECKLIST \"Center Assembly RDs at Part Origin\" \n")
   fprintf(Form "FIELD \"ChangeTextSize\"\n")
   fprintf(Form "FLOC 37 9 \n")
   fprintf(Form "CHECKLIST \"Change Text Block Sizes\" \n")
   fprintf(Form "TEXT \"Large  Text Block: \"\n")
   fprintf(Form "TLOC 39 11 \n")
   fprintf(Form "TEXT \"Medium Text Block: \"\n")
   fprintf(Form "TLOC 39 13 \n")
   fprintf(Form "TEXT \"Small Text Block: \"\n")
   fprintf(Form "TLOC 39 15 \n")
   fprintf(Form "FIELD \"TextBlockLarge\"\n")
   fprintf(Form "FLOC 55 11 \n")
   fprintf(Form "INTSLIDEBAR 3 3\n MIN 1\n MAX 60\n FGROUP\"TxtBlock\" \n")
   fprintf(Form "FIELD \"TextBlockMedium\"\n")
   fprintf(Form "FLOC 55 13 \n")
   fprintf(Form "FIELD \"TextBlockSmall\"\n")
   fprintf(Form "FLOC 55 15 \n")
   fprintf(Form "FIELD done\n")
   fprintf(Form "FLOC 6 18\n")
   fprintf(Form "MENUBUTTON \"Done\" 6 3\n")
   fprintf(Form "FIELD cancel\n")
   fprintf(Form "FLOC 16 18\n")
   fprintf(Form "MENUBUTTON \"CANCEL\" 6 3\n")
   fprintf(Form "ENDTILE\n")
   fprintf(Form "ENDFORM\n")
   close(Form)
); end defun  - createRotateRDForm
  • DE202408202727
    DE202408202727 over 14 years ago
    See attached. Let me know if it's not what you meant.
    Dave
    RotateSilkAssyRD.zip
  • AndyZhang
    AndyZhang over 14 years ago
    Hello Dave,
    Good work, thanks for your help.
    I will double test the code later, since there are some symols which are not fixed/locked, the code can not move the silkscreen to the component center.But when I choose ignore fixed property, the all silkscreen can be adjust well.
    I suspect there are any worry members has been excluded in the text list.
    If I diagnose this problem, I will let U know.
  • Mstrghettorigg
    Mstrghettorigg over 14 years ago
    Hello Dave,
     Is there one that can also rotate silk screen and assembly text on package geometry?
     I tried making some modifications, but I have no idea what I am doing so I did not have any success.
    Please let me know.
  • E Hudson
    E Hudson over 13 years ago
    Has anyone tried running this in 16.5? I am new to Cadence and trying to speed up the process on our designs. We have a plethora of components so rotating silkscreen on by one is very painful. I tried running the skill and this is what I get.
    Skill > load("/Cadence/test_area/RotateSilkAssyRD.il")
    function RotateSilkAssyRD redefined
    function doRotateSilkAssy redefined
    function rotateSilkAssy redefined
    function createTextBlock_RD redefined
    function rotateRDForm_Action redefined
    function createRotateRDForm redefined
    t
    It does not look like it does anything else. No silk was rotated on the design. Is all it doing is setting variables?
    Kind Regards
    Ed
  • DE202408202727
    DE202408202727 over 13 years ago
    You will need to run the code once it is loaded. Do this by typing "rotate_silkassy" on the command line.
    See attached. It includes a couple of tweaks.
    Dave
    RotateSilkAssyRD.2.1.zip
