  3. How to Highlight Pin Pair Dbid from axlPinPairSeek
  • Subscribers 159
  • Views 13341
aeris
aeris over 14 years ago
is there a reserved word(axl command) to highlight pin pair dbid similar to what constraint manager is doing? I tried using axlSingleSelectObject but its not working
 thanks
  • fxffxf
    fxffxf over 14 years ago
     Assuming you have a pinpair dbid (dbid->type=="PIN_PAIR") then you can use axlHighlightObject
  • aeris
    thank you, this one works, but is there something like when user clicks on other area of the board file then the hilighted pin pair will automatically unhilight without calling axlDehighlightObject
