  3. Script Env file
  • Subscribers 159
  • Views 14141
Script Env file
LP2R4T
LP2R4T over 14 years ago
Can anyonre help me?
 How can I run a script file (*.scr) from the Env file?
So that everytime I am opeing a new board the script is being run.
 Thnaks in advance.
  • eDave
    eDave over 14 years ago
    An alternative method is to use the axlTriggerSet Skill function within your allegro.ilinit file. You can call a script from within the function called by the trigger command.
  • LP2R4T
    Thanks Dave,
     It works but I would like my script to be trigged everytime I am opening the Contranint Manager instead of everytimne a database is open.
     Any Ideas?
  • LP2R4T
    Dave,
    The best solution would be to have a specific menu added to the Contraint Manager so that users can select the menu if they want the skill function to be run.
    Where are the menu alled up for the Constraint Manager?
  • eDave
    I don't think the Constraint manager is customisable.
