  3. automatic silkscreen
  • Replies 19
  • Subscribers 166
  • Views 28036
ashok123
ashok123 over 15 years ago
is it possible to do silkscreen cleanup automatically. is there any skill or script for that?
  • ashok123
    hi dave, When i run silkutils command "silkscreen check v8.23" dialog box is opening. in that dialog box i dont know to set values. if i run with the default values, there is no change in the silk and assembly layers. its just there as it is. even if i give some values and when i run , there is no change in silk. can u tell me how to set the values to do silk cleanup.
  • DE202408202727
    DE202408202727 over 15 years ago
    There is no automatic cleanup. This is partially done when you run the Allegro/Manufacturing silkscreen utility to copy the silkscreen to the Manufacturing layers. The default settings should be OK for starters. Just run "Check All".
  • ashok123
    ok dave. can we able to keep the refdes just outside the component without touching the silk line of the component by using this skill file.
  • DE202408202727
    It does check that text doesn't get to close to lines and that refdes text is closest to its parent.
  • ashok123
    ok Dave..thx
