  3. automatic silkscreen
  • Replies 19
  • Subscribers 166
  • Views 28048
ashok123
ashok123 over 15 years ago
is it possible to do silkscreen cleanup automatically. is there any skill or script for that?
  • DE202408202727
    DE202408202727 over 14 years ago
    I posted a file recently. It's attached here again.
    In Skill (or allegro.ilinit):
    loadContext("EDAVE_clearPinSilk.cxt")
    axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk ?cmdType "interactive")
    Type  clear pin silk on the command line to execute the code.
    The default values are 0.25mm for clearance and  0.21mm for the minimum lenght line to leave behind.
    You can change these values by adding your own to the end of the command. eg:
     clear pin silk 0.2 0.1
    Dave
    EDAVE_clearPinSilk.zip
  • soori3
    soori3 over 14 years ago
    Hello Dave,
    Thanks for your reply...
    I have placed the context file in skill folder and followed your instructions as you mentioned above but i am getting the following ERROR
    Skill > clear pin silk
    E- *Error* eval: unbound variable - pin
    ERROR
    Skill >
  • DE202408202727
    Type the command in the Command console - not the Skill window.
  • soori3
    It works great thank you Dave ....
    Suresh Annam
