  3. axlSetparam help to update artwork settings
  • Subscribers 159
  • Views 15622
Nagaraj Shanmu
Nagaraj Shanmu over 14 years ago
All,
I am trying to change the artwork setting from negative to positive as below
Skill >  r = axlGetParam("artwork:GND1")
param:79278264
Skill > r->negative = nil
nil                                 ---------------------------------------  here the value is changed converting negative to positive
Skill > axlSetParam(r)
nil
but when I use the axlSetparam to update its not getting updated. Can anyone help on this?
Appreciate your help.
Nagaraj
ciena logo
  • fxffxf
    fxffxf over 14 years ago
     In the documentaton (table 2-35), the column with "Set?"must have a "yes" for the field to be supported by axlSetParam. Editing this field is not supported.
  • Nagaraj Shanmu
    Thanks Frank. Is there a way to change the artwork film setting to convert negative to positive using skill?
    I can think of deleting the film and recreating using axlDBCreateFilm command but just to know if other option is available to just update existing film parameters.
    Nagaraj.
  • fxffxf
     The only way I know is; save the parameters, delete the film via axlDeleteObject, then re-add it via the misnamed axlfcreate API
  • Nagaraj Shanmu
    Thanks this should help to get the task done.
    Good day!!
    Nagaraj
  • WMILan
    WMILan over 10 years ago
    Can I use axlSetParam() to toggle the Negative Artwork box in the Layout Cross Section? Or is that field not supported?
    I'm trying to write a SKILL to automatically toggle that setting specifically change only Plane layers from positive to negative or vice versa in the Layout Cross Section.
    Thanks to anyone for the help.
