  3. Output PTH Drill and Slot Count using Skill
  • Subscribers 159
  • Views 13326
ahood
ahood over 14 years ago
Hi
I Am trying to output a seperate hole count for PTH Drills and PTH Slots. I curently have a script that counts them together
I believe I need to access the Hole Type property (i.e. Circle_Drill, Oval_Slot or Rectangle_Slot) to be able to achieve this.
Can my existing Skill Script be modified to do this easily? see section of skill script below:
foreach(pin pins_list
if(pin->isThrough == t then
pin_xy = pin->xy
padstack = car(pin->pads)->parent
drill = padstack->drillDiameter
pin_name = padstack->name
plating = axlDBGetDrillPlating(pin_name)
if(drill > 0 then
if(rexMatchp("NON PLATED" plating) == nil then
if(member(drill pdrill_list) == nil then
pdrill_list = cons(drill pdrill_list)
else
if(member(drill npdrill_list) == nil then
npdrill_list = cons(drill npdrill_list)
pin_count++
ahood
  • fxffxf
    fxffxf over 14 years ago
    To access the request info:
     hole type: padstack->holeType
    Without going to the Allegro Skill doc:
        -You can see all available attributes by: padstack->?
        - & attributes and values by: padstack->??
