  3. 4 Terminal PCB Footprint
  • Replies 9
  • Subscribers 160
  • Views 15365
MikeSD
MikeSD over 14 years ago
I have a component (MOSFET) that is a 3 terminal device, in TO-92.  In a surface mount, it's 4 pins (3 pins and a tab).
I'm not sure the best way to deal with this.  On the datasheet, each connection is D, G, S and D(tab).  But on the footprint it's numbered (1, 2, 3, 4).
I have two options.
1) Make the footprint 4 pins (each differently numbered, 1, 2, 3 and 4).  But this requires adding a 4th pin on my component in the schematic capture, which looks strange. Most transistors are only 3 pin devices.
2) Make a footprint that has 3 pins with the center pin large to include the tab area.  But this removes routing options under the componet.
I initially tried 4 pins with numbers 1, 2, 3 and 2 for the tab but got an error becuse two pins had the same number.
What is the best or most appropriate way of handling this?
  • Randy R
    Randy R over 14 years ago
    One other method is to make the logic symbol 3 pins and then have a physical symbol with 3 connect pins and one mechanical pin for the tab.
  • MikeSD
    Good point.  I'll see what that takes.  I've done this before.  I think it's just a matter of attaching the mechanical pin.  How is it attached to the drain connection in the layout?  Is that just by attaching the net to the mechanical point?
  • eDave
    eDave over 14 years ago
    You should be doing this as a four pin package and hide the second drain pin - shorted to the first - on the schematic symbol.
  • MikeSD
    If I make it a 4 pin device, which is what I have now, how do I hide the pin?  I don't see any options in the part editor.   I do see a "visible" check box, but it's only active if I make it a "power" pin.
    Also, how would I "short" it to the other pin?  I don't see the equilevant of "wire" and no way of hiding that also.
  • eDave
    It's certainly possible (and common) in Design Entry HDL (Concept) but I'm not sure about Capture, if that's what you are using. Someone else will have to give you the steps but our librarian does it regularly.
