  3. How to keep your variables in the design?
  • Replies 25
  • Views 18500
Silver John
Silver John over 15 years ago
Hi, All.
I have a script that creates a form with several fields. I want to save the contents of these fields in design, and the next time when I open the design and launches the script I have already configured the form.
There are functions for including the file or string to .brd-file, there are functions for working with the properties of the design...
What is the best way to save my settings?
Maybe someone has an example code?
Thank you.
  • DE202408202727
    DE202408202727 over 15 years ago
    I just add properties to the design. Just take care to suitably name the properties to avoid conflicts.
  • Silver John
    Thank you, Dave.
    How long you use this method? Wasn't problems?
  • DE202408202727
    I have used this method for several years without a problem.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi fxffxf
    I've been trying to get this to work using the desribed method but don't seem to be able to go back to an disembodied property list.
    I have the following simple example
    mylist = ncons(nil)
    mylist->ccw = t
    mylist->middle = nil
    mylist->cx = 0.12
    mylist->cy = 10.192
    mylist->layer = "TOP"
    mylist->stype = "LEFT"
    dataString = sprintf(nil " '%L" mylist)
    axlCreateAttachment("_ns_planar_settings" nil 0 'string dataString)
    The above does create my attachment. I can easily read it using
    a_id = axlGetAttachment("_ns_planar_settings" 'string) which returns an attachment id
    mylist1 = errsetstring(a_id->data) will return a list, but I cannot access the data using -> syntax
    typing mylist1 at the skill development window works. but still how do I access the list?
    I would expect mylist1->layer but that returns nil
    Skill > mylist1
    ((nil stype "LEFT" layer "TOP"
        cy 10.192 cx 0.12 middle
        nil ccw t
    Best regards
    Ole
  • Silver John
     Find two differences ;)
    Skill > mylist1 = errsetstring(a_id->data)
    ((nil middle nil ccw t))
    Skill > mylist
    Yes, I too faced with this problem.
    You can use: mylist1 = car(errsetstring(a_id->data))
    Also, I store the data without " ' ", and add an apostrophe at the time of restoring:
    sFormData = sprintf(nil "%L" _formData)
    sFormData = attachment->data
    formData = car(errsetstring(strcat("'" sFormData)))
