  3. How to keep your variables in the design?
  • Replies 25
  • Views 18519
Silver John
Silver John over 15 years ago
Hi, All.
I have a script that creates a form with several fields. I want to save the contents of these fields in design, and the next time when I open the design and launches the script I have already configured the form.
There are functions for including the file or string to .brd-file, there are functions for working with the properties of the design...
What is the best way to save my settings?
Maybe someone has an example code?
Thank you.
  • fxffxf
    fxffxf over 14 years ago
    As per the post http://www.cadence.com/Community/forums/p/19664/1293598.aspx#1293598
    You need to do a
        dataString = sprintf(nil " '%L" my_list)
    to convert the disembodied property list back into a string before storing it back in the database.
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    Yes, that's correct
    I just missed setting a_id->data = dataString
    Thanks for the help.
    Best regards
    Ole
  • pcbnagaraj
    pcbnagaraj over 14 years ago
    All,
    What’s the maxim characters i.e. string length I can have in the variables?
    I used property but they can store only limited length of characters. I need to store a lot of intersection points on the lines.
    Example xy(2345.45:1236.55) like this about 100 points in a variable.
    When I use property they gave me error after few entries.
    Nagaraj.
  • Silver John
    Silver John over 14 years ago
    I think, enough, for your purpose, try.
    For example, my attachment is 209 characters.
    It is also possible to attach a file...
  • pcbnagaraj
    Thanks Silver John for confirmation.
    Nagaraj.
