  3. Temporary highlight
  • Replies 11
  • Views 21634
Temporary highlight
Khurana
Khurana over 15 years ago
Is there a way to find out the dbid of an object that's temporary highlighted?  If yes, how - thanks!
  • Randy R
    Randy R over 15 years ago
    I see.  I was thinking about someone using the Show Element command.
  • Khurana
    Thanks John & Randy - say I have a .brd...I now invoke highlight command on the symbols (footprints in brd) using Display > Highlight > select Symbols in Find Filter > left click on the symbols.  At this point, I'd like to know how to obtain the dbid of the symbols that are highlighted...is there a way to do that?  I was doing this by invoking axlIsHighlighted() on the components but I guess I need to use symbol def or symbol or some other def?
  • Randy R
    In that case, I think axlGetSelSet() would work for what you're trying to do (see below).
    last pick:  3600.0000  5200.0000
    No element found.
    Skill > axlGetSelSet()
    nil
    last pick:  3500.0000  5600.0000
    Symbol "Npin1181" assigned color.
    (dbid:247928168)
    Skill >
    Of course, this only works for the currently selected symbol and while you are still in the highlight command.  To get more than one symbol you could right-click and Temp Group.  Hopefully this helps for what you're trying to do.
  • Silver John
    Silver John over 15 years ago
    Still, we can check and temporary highlighting:
    ; "object" contain dbid
    if( axlDehighlightObject(object nil)
    then
        highlighted = t ; object is temporary highlighted
        axlHighlightObject(object nil) ; restore highlighting
    else
        highlighted = nil
    And  I did not understand a bit: the topic is called "Temporary highlight", but you use Display> Highlight, which gives permanent highlighting ...
  • Khurana
    Will try this...will blame Temporary highlight on what it says in Color Dialog under Display...thanks!
