  3. Align tool
  • Replies 14
  • Subscribers 168
  • Views 20423
Align tool
Silver John
Silver John over 15 years ago
Present to you the tools to align objects on PCB.
Welcom for comments, bugs, suggestions.
Questions?
Who wants to can join to development.
Code in the repository: github.com/.../align
Installation described in the README.md.
Issues:
Icons not works in Allegro 15.x
axlUIMenuRegister() not work in Allegro 15.x
 And how it looks:
Align tool UI
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    You could also use the iangle command
    funckey r iangle 90 to rotate 90 degree each time you press r
    or if you need finer adjustments set the angle to something less or use uppercase R for another angle increment
    Best regards
    Ole
  • Silver John
    Silver John over 14 years ago
    Enough offtopic, guys.
    Ole, you have some experience, maybe you answer my questions?
    Thanks.
  • alanf
    alanf over 14 years ago
    Many thanks guys.  This makes life alot easier.
    The only outstanding problem I'm having these days is the comunications between Orcad Cpature and Layout. (V16.5)
    I would like to have better comunications between capture and layout. I'd like to be able to select a part in one and have it go to the location of the other so both footprint and schematic symbol are viewed (2 screens) at the same time.
    Alan Fisch
    APF Circuit Design
    Ottawa, Ontario
  • GM1000
    GM1000 over 3 years ago
    Anyone know how to make this work on Allegro 22? It is a fantastic component and silk screen align tool. I use it on my 16.5 but now moving to 22 and it does not load ):
