  3. Skill Function to return the OS running
  • Replies 7
  • Subscribers 160
  • Views 14835
Khurana
Khurana over 14 years ago
I know about cdsPlat() but it's not suitable since it just returns "wint" - I'd like to know of a function that tells me what version of Windows I have got installed i.e. Win XP or Windows 7 without getting too creative.  Any pointers are appreciated!
  • eDave
    eDave over 14 years ago
    when(zerop(system("ver >os.version"))
                q = axlDMOpenFile("MISC", "os.version", "r")
                fscanf(q, "%s %s %s ", rubbish, platform, os)
                axlDMClose(q)
                deleteFile("os.version")
  • Khurana
     Thank you Dave!
  • Ejlersen
    Ejlersen over 14 years ago
    Hi All
    Notice that you cannot be completely sure the output of "ver" is in the same format for different Windows Operating Systems.
    I've seen a response like Microsoft Windows [version 6.1.7600] (seen for Windows 7, eventhough google says it should say version 7)??
    For XP, I've seen Microsoft Windows XP [Version 5.1.2600]
    So you would need another parameter to fscanf to get a more reliable result and also, you would need to test the version number to determine the correct OS
    Best regards
    Ole
  • Khurana
    Ole,
    I didn't check the output of "ver" on Win 7 before asking this question and yeah I have experienced the same problem.  So, instead of relying on the output of "ver" to figure out the os I used isDir() to check to see if C:\Program Files (x86) folder exists on the pc; if it does then it's a Win 7 otherwise it's Win XP.
    Varun
  • Khurana
    Btw, another engineer here had another idea: use output of "systeminfo", which is definitely better.
