  3. Problem with obtaining correct bounding box
  • Subscribers 159
  • Views 15276
KetCadence
KetCadence over 14 years ago
 Hello All,
I am working on one of the module where I need to obtain bounding box for some of the components of PCB using skill script.
I have already written skill script to obtain bounding box for selected components.
I am using  "axlDBGetExtents" function for this.
However, I am facing one problem with this method.
Problem:
Bounding boxes obtained using this function are larger than what I need.
For my purpose, I need bounding box prefereably (or I would say ideally) of the size of top surface of the component.
My Current Method:
I have used "t" as second argument for axlDBGetExtents(id t) function.
According to documentation,  by using "t" as a second argument, bounding box only for visible parts of component is selected.
I am controlling visibility by using "Display->Color/Visibility" option.
I am choosing to disable all options except "Package Geometry -> Assembly_Top & Display_Top".
Please let me know if I am doing something wrong here as I have started using this software only a month ago.
Any suggestions that would help me in resolving this problem are welcome.
  • Silver John
    Silver John over 14 years ago
    I'm using specific layers DFA_BOUND_xxx or PLACE_BOUND_xxx and bBox property.
    As I do it:
    ; Get object boundary box.
    ; First trying get Dfa_Bound_Top(Bottom)
    ; if Dfa not present trying Place_Bound_Top(Bottom)
    ; if Place not present get bBox property.
    defun( getObjectBBox (object)
        let( ( objectChildren child dfaLayer placeLayer result)
            if(object->isMirrored
                then dfaLayer = "PACKAGE GEOMETRY/DFA_BOUND_BOTTOM" placeLayer = "PACKAGE GEOMETRY/PLACE_BOUND_BOTTOM"
                else dfaLayer = "PACKAGE GEOMETRY/DFA_BOUND_TOP" placeLayer = "PACKAGE GEOMETRY/PLACE_BOUND_TOP"
            objectChildren = object->children
            ; only Symbols have objectChildren
            if(objectChildren then
                ; find Dfa_Bound_ shape
                foreach( child objectChildren
                    if((child->objType == "shape" && child->layer == dfaLayer) then
                        result = child->bBox
                ; find Place_Bound_ shape
                if(!result then
                        if((child->objType == "shape" && child->layer == placeLayer) then
            if(!result then result = object->bBox)
            result
        ) ; let
    ) ; defun
  • KetCadence
    Hi John,
     Thanks very much for your reply.
     Your method gave me the required size bounding boxes for components.
