  3. Getting path for loaded skill file
  • Subscribers 160
  • Views 17793
Ejlersen
Ejlersen over 14 years ago
Hi
Is there an easy way to get the path of a loaded skill file?
Best regards
Ole
  • aCraig
    aCraig over 14 years ago
    Try this to get the first location:
    found = nil
    paths = getSkillPath()
    while(paths && !found
        path = car(paths)
        paths = cdr(paths)
        when(isFile(strcat(path "/" skillFileName))
          found = t
    Use foreach to get the last location.
    Craig
  • Ejlersen
    Hi Craig
    Thanks for the answer, althoug it is in line with what I already do.
    Suppose a skill file exist in several places, then the search needs to take the load preceedence into order. So I was hoping for an axl function to retrieve the path.
    Best regards
    Ole
  • eDave
    eDave over 14 years ago
    Hi Ole, I suspect that, once the code is loaded and in memory, it is not possible to tell where it is loaded from. The Skill developers reference manual has a "whereIs" function. I'm not certain whether this would help you but does indicate that this information might be available in debug mode. A method to resolve this might be to put some code in the utility to identify the load path on load but I can't think how to do that without hijacking the load command. I can see how this could be useful. Please let us know if you find a good solution. Dave
  • aCraig
     Hi Ole,
    I did find a Skill command "which" which does essentially what my sample  code  does. I agree with Dave on once it's loaded you don't really know where it was loaded from, unless you always use the Skill path to do the search for the file.
    Craig
  • PCB George
    PCB George over 14 years ago
    I typically add a printf statement as the last line of code.  Since it is outside the functions of the code, it prints out the routine name, version, and date when the code is loaded.  I use it as a sanity check to make sure the proper version is loading from the site skill path, You could probably use something like that to include the path if you wanted to.
    George
